710
Reports (WinGrd) 4 questions
Hi all,
I'm exporting 3 grids to the same section
 Dim UG_to_Export_1 As Infragistics.Win.UltraWinGrid.UltraGrid
 Dim UG_to_Export_2 As Infragistics.Win.UltraWinGrid.UltraGrid
 Dim UG_to_Export_3 As Infragistics.Win.UltraWinGrid.UltraGrid
UGDE.AutoSize = DocumentExport.AutoSize.None
UGDE.Export(UG_to_Export_1, Section1)
UGDE.Export(UG_to_Export_2, Section1)
UGDE.Export(UG_to_Export_3, Section1)
1) How I can add a blank space between the grids when exported to the PDF?
I mean, all 3 grids are rednered one after the other, without any delimiter or space.
If I go with 3 sections, for some reason a pagebreak is added.
2) For some wierd reason, the exporting creates 1 or 2 extra blank pages...Why is that?
The last part only includes the footer and page numbering.
3) How I can make the grids to be centered on the page?
4) Is it possible to add a watermark?
I mean if there is a built-in feature to do that.
Thanks in advance for any help!
