Almost everything is in the title, I want to replace the built-in right click menu of a ultraFormattedTextEditor by my own, I can't find how, can you help me ?
David
ok, thanks :)
Hello David, I believe you can use own context menu by replacing standard one. Here is the code snipped how to do add custom context menu with few items and handle ther click event: ContextMenu menu = new ContextMenu(); MenuItem contextMenuItem; contextMenuItem = new MenuItem("Context Menu Item 1"); contextMenuItem.Click += new System.EventHandler(this.contextMenuItem_Click); menu.MenuItems.Add(contextMenuItem); contextMenuItem = new MenuItem("Context Menu Item 2"); contextMenuItem.Click += new System.EventHandler(this.contextMenuItem_Click); menu.MenuItems.Add(contextMenuItem); contextMenuItem = new MenuItem("Context Menu Item 3"); contextMenuItem.BarBreak = true; contextMenuItem.Click += new System.EventHandler(this.contextMenuItem_Click); menu.MenuItems.Add(contextMenuItem); this.ultraFormattedTextEditor1.ContextMenu = menu; private void contextMenuItem_Click(object sender, EventArgs e) { // Implement the functionality for clicked menu items here }I hope this helps.Sincerely,Dimitrina GinevaDeveloper Support EngineerInfragistics, Inc.
