245
Activate the child form from the ultragrid.
i have a form.in that i have the  wingrid.In that grid we have dropdown column. if the drop down column has changed then we need to open the child form.The child form is opening but i am unable to do select on the first click. its working fine in the second click
We have written the code in this below event
ugrdWorkCard_AfterCellListCloseUp
if (e.Cell.DataChanged)
                         if (cellValue == employee.mark)
                              // Here i need to open the form.and i want to use only the showdialog() and in a single click i want to select
Can u tell how to do that. Its quite urgent.
  • 430
    Suggested Answer
    Try using CellListSelect event of the dropdown.
    and to check which column is being click u can use select case
    ex:
    select case e.cell.column.tostring
    case"Column Header"
    call the form here..
    Hope it will work
  • 17259
    That's probably because AfterCellListCloseUp is happening before DataChanged becomes true. Try the CellChange event.
