I am setting datasource of wingrid with custom object which is having hierarchical data. Grid is showing data in bands (3 bands). But I am finding problem with 3rd band, when I expand 2nd band 3rd band doesn't paint. It paints when I click on any cell of 2nd band.
I also want to remove extra columns from band 2 and band 3. I tried with
e.Layout.Bands[ 1 ].Columns[ "ABC" ].Hidden = true;
InitializeLayout event of grid, but it it showing band 1 doesn't have any column.
I am using Infragistics Version=7.2.20072.61.
-Neeraj
Well, I can't be completely sure. I do remember that there was a bug like this that was fixed. But it's always possible that the bug you are experiencing is different than the one I remember. The only way to be sure is to try it out.
If you don't want to upgrade, then I recommend that you create a small sample project which demonstrates the problem and post it here. I will run it with the latest service release and see if the problem is still there.
Are you sure this problem will resolve in latest releases?
Is this bug in version 7.2.200072.61?
Hi Neeraj,
That's a pretty old version. I recommend that you get the latest service release. My Infragistics Keys and Downloads - Download Anything and Everything You Own
