Hii
I am using ultratoolbarmanager and have ribbon in which tabs are there.At design time i am placing a picturebox on ribbbon tab.
When i run the application and right click on toolbar and select "Minimize the ribbon" it minimizes the ribbon and when i click on any tab on ribbon say riibbon2 then
floating ribbon comes but no image. When i double click on tab the ribbon gets maximized and now image comes.
I want that Image should always be displayed whenever ribbon comes.How should i do that.
See snap
rhealsoftTakeoff,
What build of NetAdvantage for Windows Forms are you seeing this with? I tried to reproduce the issue you're seeing but have not been able to; I set the Ribbon's TabSettings.ClientAreaAppearance.ImageBackground property to an image, and then set the ImageBackgroundStyle property to Centered. After I minimized the ribbon and then floated it out, I was still able to see the image. Are you setting different properties?
~Kim~
