I have a columnchooser control working as I expect on an UltraWinGrid, but want to see the "official" way of capturing the event of when a user clicks a checkbox in the columnchooser. I want to capture this event and do some processing with the selection they have made.
What is the best way to accomplish this?
Thanks!
Use the AfterColPosChanged event of the grid.
Yes, this seems tricky as the other poster talked about. How could I be sure this event came from the column chooser? Is there a property to tell me if the chooser is open/visible?
It's not tricky at all. The event args tell you what action is taking place. Check e.PosChanged and it will tell you if a column was moved, swapped, resized, or in this case it's hidden state was changed.
Excellent! Thank you. I will try this and let you know if I have further questions.
