Mike,
I have a slightly different question on ultrawingrid. I have one custom business object (CBO1) with 5 properties. Four of these properties are of simple data types such as string, long etc. The fifth one is another cusom business object (CBO2) with its own set of say, 10 properties. I want to show four properties of CBO1 and 10 properties on CBO2 in the same row.
Thanks,Sunil
I am going with the first option.
In addition to exposing those sub-properties as a property of your cbo1 class, there are two other possible options:
I don't see a way to bind directly to the inner cbo2 through cbo1.
The only way would be to add properties to cbo1 that reflects the one from cbo2.
for example:
class cbo1
public string cbo2Name
get{return cbo2.Name;}
