I have a Windows form having a UltraFormattedTextEditor, and a button.
When I click that button it will insert some text("User") in the UltraformattedTextEditor . When I insert that text i want to change the background of the text to "Yellow" and make it Bold, and after that if i type something it will appear as normal text, with default background.
i want to achive it through C# code. If it is possible, please provide me some sample.
private void ultraButton1_Click(object sender, EventArgs e) { ultraFormattedTextEditor1.Appearance.BackColor = Color.Yellow; ultraFormattedTextEditor1.Appearance.FontData.Bold = Infragistics.Win.DefaultableBoolean.True; ultraFormattedTextEditor1.Text = "User"; }
private void ultraFormattedTextEditor1_ValueChanged(object sender, EventArgs e) { if (ultraFormattedTextEditor1.Text != "User") { ultraFormattedTextEditor1.Appearance.BackColor = Color.Empty; ultraFormattedTextEditor1.Appearance.FontData.Bold = Infragistics.Win.DefaultableBoolean.Default; } }
hope this helps
Hi, You can use the standard styles for applying a background and change the font appearance here is some help about this:http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html/infragistics2.Win.Misc.v8.2~Infragistics.Win.FormattedLinkLabel.UltraFormattedTextEditor~ContextMenuItems.htmlAbout the clearing question you, it seems that you want to clear all styles that you set, but you didn’t mention is there any difference where (in the formatted text or not) you type something and do you want to clear formatting only for the typed text or for the whole content.Here is some help how to clear specific style:http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html/WinFormattedTextEditor_Clearing_Specific_Styles_from_Formatted_Text.htmlI make sample which clear the styles that you mentioned by typing in the formatted editor text area.You also can look at the sample project in your Sample Browser under section “Commands and editors/ToolBars/Ribbon with Formatted text editor”.I hope this information is helpful.Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
