215
Trying to duplicate a repeatable Node
Kind of hard to explain, but I have a tree and tree represents tables in a relational database, basically the Dictionary.
Well if you click the parent node, it builds the children and grandchildren.  So now let's say I select TABLE1 as the parent node, I wil get a Child node called DEPENDS ON, this will drill down to other "parent" names, let's say TABLE2.  Now if I select TABLE2, it basically acts like if it was  a Parent and the same process repeats where I get another Child called DEPENDS ON.  Now this already works in C# controls.
Now for my problem trying to duplicate this with the UltraWinTree.  Only one ACTIVENODE can be enabled at a time, so when I click on TABLE2 in my example above, I get an error since I already have the ACTIVENODE of the first Parent.
I attached the code where I get the error when I click on the TABLE2 scenario, this always works the first time since I get my first ACTIVENODE which is the first Parent selected.
I get the error message that the Key already exist: Depends on
if (oNode.GetNodeCount(false) < 1)
                       /// Get Depends On only if it is a file
                       if (ParentIsFile && IsFile)  // we add the dependants and the depends on
                           /// Get Depends On
                          UltraTreeNode oDependsOn = new UltraTreeNode("Depends On");
                          //This is the code change to using the UltraTree control
                          //This is where I get the error message that the Key already exist: Depends on
                          this.ultraTree1.ActiveNode.Nodes.Add(oDependsOn);
                            //Old code from Native Tree control
                           //this.ultraTree1.SelectedNodes.Nodes.Add(oDependsOn);
                           foreach (DataRow dr_GetTableDefSql in dt_GetTableDefSql.Rows)
                               string temp = dr_GetTableDefSql["ColumnName"].ToString();
                               if (temp.ToLower().EndsWith("id"))
                                   string strRelative = temp.Trim().Substring(0, temp.Trim().Length - 2);
                                   if (strRelative.ToLower() == "user")
                                       strRelative = "SyStaff";
                                   dv_SyDictTables.RowFilter = "Tablename = '" + strRelative.Trim() + "'";
                                   if (dv_SyDictTables.Count > 0)
                                       if (strRelative != TableName)
                                           UltraTreeNode oChild = new UltraTreeNode();
                                           oChild = new UltraTreeNode(strRelative);
                                           oDependsOn.Nodes.Add(oChild);
