1284
How to set MaskInput in UltraWinGrid Column for the Below validation
In UltraWinGrid one column should be in the below format.
Input string should be in range Like below
User can enter the range as 1,000-1,999
or they can enter the range as  $1,000-$1,999
Number ranges from 500 to 50,000
Can anybody help me how can I achieve this.
  • 469350
    Suggested Answer
    I'm not entirely sure that I understand what you are asking. Which part of this is giving you trouble? What's the datatype of this column? Or is this two different columns?
    If this is a single column and you want to allow the user to enter commas and dollar-signs optionally, then you will probably need to use a DataFitler and convert the string the user types into a value that the column's data type can handle and vice versa.
