Our application is winforms userControl which is invoked within VB6 using a interop, this works perfectly fine. However with that said, there is a senrio where the system throws a RT.
Step1: Open a form with wingrid that has data and open grid filter,
Step 2: Close the form, without collapsing the filter dropdown. Even though the form is closed some kind of object remains on the MDI
Step 3: Open another form and click on any kind of drop down. The system blows with the below exception.
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************System.ObjectDisposedException: Cannot access a disposed object.Object name: 'ValueListDropDownUnsafe'. at System.Windows.Forms.Control.CreateHandle() at System.Windows.Forms.Control.get_Handle() at Infragistics.Win.DropDownManager.OwnsControl(Control control) at Infragistics.Win.DropDownManager.HandleClosingOfOpenDropDowns(Control owner) at Infragistics.Win.DropDownManager.DropDown(DropDownManagerParameters dropDownManagerParameters) at Infragistics.Win.ValueListDropDown.ShowHelper(Rectangle editRect, Int32 index, Boolean isDroppingDown) at Infragistics.Win.ValueListDropDown.DoDropDown(Rectangle editRect, Int32 index) at Infragistics.Win.ValueList.Infragistics.Win.IValueList.DropDown(Rectangle cellAreaInScreenCoords, Int32 index, String text) at Infragistics.Win.UltraWinGrid.ColumnHeader.OnClickFilterDropDown(HeaderUIElement headerElem, Boolean shiftKeyDown) at Infragistics.Win.UltraWinGrid.FilterDropDownButtonUIElement.OnMouseDown(MouseEventArgs e, Boolean adjustableArea, UIElement& captureMouseForElement) at Infragistics.Win.ControlUIElementBase.ProcessMouseDownHelper(Object sender, MouseEventArgs e) at Infragistics.Win.ControlUIElementBase.ProcessMouseDown(Object sender, MouseEventArgs e) at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e) at Infragistics.Win.UltraControlBase.OnMouseDown(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///x:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------Cmc.UI.Winforms.CampusVue.Session Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CampusVue.Session.DLL----------------------------------------Cmc.UI.Winforms.CampusVue Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CampusVue.DLL----------------------------------------Cmc.CampusLink.Client.Proxy Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.Client.Proxy.DLL----------------------------------------Cmc.CampusLink.Client.BusinessEntities Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.Client.BusinessEntities.DLL----------------------------------------Cmc.CampusLink.BusinessProcesses Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.BusinessProcesses.DLL----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------Cmc.CampusLink.Soa Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.Soa.DLL----------------------------------------Cmc.CampusLink.CodeAccessSecurity Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.CodeAccessSecurity.DLL----------------------------------------Cmc.CampusVantage.Client Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusVantage.Client.DLL----------------------------------------System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------Cmc.UI.Winforms.CentralSecurity.Interfaces Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CentralSecurity.Interfaces.DLL----------------------------------------Cmc.UI.Winforms.CentralSecurity.Foundation Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CentralSecurity.Foundation.DLL----------------------------------------System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Cmc.CampusLink.BusinessEntities Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.BusinessEntities.DLL----------------------------------------ksezpq49 Assembly Version: 11.0.0.71 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Core Assembly Version: 3.5.0.0 Win32 Version: 3.5.30729.1 built by: SP CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll----------------------------------------t5pcwpjq Assembly Version: 11.0.0.71 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------CMCClientLibrary Assembly Version: 1.0.1809.20554 Win32 Version: 1.0.1809.20554 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/CMCClientLibrary.DLL----------------------------------------CMCBase Assembly Version: 0.0.1.20552 Win32 Version: 0.0.1.20552 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/CMCBase.DLL----------------------------------------System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------Cmc.UI.Winforms.CampusVue.Interfaces Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CampusVue.Interfaces.DLL----------------------------------------Cmc.UI.Winforms.CampusVue.Messages Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CampusVue.Messages.DLL----------------------------------------CmcFAControls Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/CmcFAControls.DLL----------------------------------------Csla Assembly Version: 3.0.0.0 Win32 Version: 3.0.0.0 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Csla.DLL----------------------------------------Infragistics2.Win.UltraWinChart.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinChart.v8.2.DLL----------------------------------------Infragistics2.Win.UltraWinGrid.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinGrid.v8.2.DLL----------------------------------------Infragistics2.Win.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.v8.2.DLL----------------------------------------Infragistics2.Shared.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Shared.v8.2.DLL----------------------------------------Infragistics2.Win.UltraWinGrid.ExcelExport.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinGrid.ExcelExport.v8.2.DLL----------------------------------------Infragistics2.Excel.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Excel.v8.2.DLL----------------------------------------Cmc.DataAccess Assembly Version: 11.0.0.71 Win32 Version: 11.0.0.71 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.DataAccess.DLL----------------------------------------System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll----------------------------------------System.ServiceModel Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.2152 (SP.030729-0100) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll----------------------------------------System.Runtime.Serialization Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.2152 (SP.030729-0100) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll----------------------------------------SMDiagnostics Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.2152 (SP.030729-0100) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/SMDiagnostics/3.0.0.0__b77a5c561934e089/SMDiagnostics.dll----------------------------------------System.EnterpriseServices Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll----------------------------------------Infragistics2.Win.UltraWinPrintPreviewDialog.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinPrintPreviewDialog.v8.2.DLL----------------------------------------Infragistics2.Win.UltraWinDock.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinDock.v8.2.DLL----------------------------------------Infragistics2.Win.Misc.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.Misc.v8.2.DLL----------------------------------------Infragistics2.Win.UltraWinEditors.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinEditors.v8.2.DLL----------------------------------------Infragistics2.Win.UltraWinToolbars.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinToolbars.v8.2.DLL----------------------------------------Infragistics2.Win.UltraWinStatusBar.v8.2 Assembly Version: 8.2.20082.1000 Win32 Version: 8.2.20082.1000 CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinStatusBar.v8.2.DLL----------------------------------------System.Design Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll----------------------------------------Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------
************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /></configuration>
When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
This problem occured for us up to 12.1, but not in 13.1.
In 13.1 the combo seems to get closed when it loses the focus better.
I've taken a look at this issue, and I've discussed it with our developers as well.
Our Windows Forms controls and components are built to be used in a pure Windows Forms environment, and we also support their use in WPF. COM interop changes a lot of the "rules" significantly, however, and prevent some of the functionality of our Windows Forms toolset from working. Because of this, we do not support the use of our Windows Forms controls and components through COM iInterop.
There's a possibility that the issue may be reproducible in a pure Windows Forms environment. If so, there's also a possiblity that we may have already fixed the issue (since I note you're using the release build of NetAdvantage for Windows Forms 2008 Volume 2). You may want to test your application using the latest service release for this version of the tooslet, which you can get from the My Keys and Downloads page of our website.
If the service release doesn't resolve the issue, I recommend that you set up a test that uses only Windows Forms, and no COM interop, to see if you can reproduce the issue. If you can reproduce this in a pure Windows Forms environment, then please submit a support request and attach the sample you used to reproduce, so that we can investigate and resolve the issue.
