Current Date value cant able to select in Windows Vista. But Can select other Dates,
Is there any idea to rectify this?
Thanks in Advance
Just wild speculation here, but the control's default value is the current date, so selecting that value will not trigger the ValueChanged event, since nothing has changed. If you want to confirm whether this is the problem, change to some other date, then select the curret date and see if it works.
Hello, I am still not able to reproduce the behavior you have described eider in version 6.1.20061.1095. On which version exactly did you get this behavior. Can you provide a little more info about the version and scenario you are using. You can try getting the latest hot fix available for your version. You can download it form this link:http://ko.infragistics.com/dotnet/netadvantage/winforms/wingrid.aspx#DownloadsIf the issue still persist I think is better to reproduce it in isolated project and we can take a look at it.Let me know if that helps.Sincerely,Dimitrina GinevaDeveloper Support EngineerInfragistics, Inc.
We are using Version v6.
Unable to Select Current Date Value in UltraDatetimeEditor in Windows Vista.Other Dates working fine.
Hello, I am not able to reproduce the behavior you have described. On which version did you experience this issue. The only think that come to my mind is that you maybe handle the selected data and have some checks and this. Did you have some filtering when new data is selected. Can you provide me more information about the version and scenario you are using.Let me know if that hels.Sincerely,Dimitrina GinevaDeveloper Support EngineerInfragistics, Inc.
