840
Disable the ability for UltraExplorerBarGroups to expand/collapse?
I'm using the Groups in my UltraExplorerBar as a navigation element.  (forms are loaded when the user clicks on a group)...
I would like to disable whatever it is in the control that expands/collapses the panel when the user clicks on the header.
Is this possible?  Thank you very much in advance.
  • 69832
    Verified Answer
    One solution would be to handle GroupExpanding/GroupCollapsing, use the UltraExplorerBar.UIElement.ElementFromPoint method to hit test for the ExpansionIndicatorUIElement, and cancel the event if the hit test does not yield one:
    void explorerBar_GroupExpanding(object sender, CancelableGroupEventArgs e)
        UltraExplorerBar explorerBar = sender as UltraExplorerBar;
        bool expand = false;
        Point point = explorerBar.PointToClient(Control.MousePosition);
        UIElement element = explorerBar.UIElement.ElementFromPoint( point );
        while ( element != null )
            if ( element is ExpansionButtonUIElement )
                expand = true;
                break;
            element = element.Parent;
        e.Cancel = ! expand;
