I have a scenario where the ultratexteditor should be readonly i.e., it should act like a label. I also have a dropdowneditorbutton to the button collection of the editor.
I want to get rid of the cursor in the text box on focus. How can I achieve this?
-ng
I don't think this is possible. In order to click the editor button, the control has to be able to enter edit mode.
Perhaps what you need to do is use an UltraDropDownButton control instead of an UltraTextEditor.
The UltraTextEditor uses a .NET TextBox as its editor, so I'm not really sure that there's a great way to accomplish this. When you set the UltraTextEditor to ReadOnly, it sets the TextBox to ReadOnly as well, which will show the cursor and allow the user to select text, but prevent any changes from occuring. Normally you could prevent this by cancelling the BeforeEnterEditMode event, but this will also prevent the dropdown button from working correctly since the buttons cannot function properly without the editor being in edit mode.
-Matt
