I'm using an excel exporter on a grid where one of the columns has one value for display purposes that I want to expand with more content detail on export.
First, is there a way to do this?
I've tried hooking the various events (InitializeRow, RowExporting, CellExporting) but can't seem to find a way to set the cell value. I don't get an error when I assign the value to something like
e.GridRow.Cells[0].Value = "NEW VALUE";
but the exported value does not change.
I don't really want to change the base cell value before export, do the export and then change it back if that can be avoided so I must be missing something simple here.
I that case I would recommend submitting the issue to the support group. It sounds like there may be a bug: http://ko.infragistics.com/gethelp.
I tried changing the text in the CellExported event. The code just does
e.GridRow.Cells[e.CurrentColumnIndex].Value = "my new text";
on the cells that I want to modify. In debug is shows that the value property is changed but there is no difference in the resulting xls file.
So, I thought that this might be to late so I moved the code to the CellExporting event and was able to modify the text in the cell.
I'm still not able to get what I really am trying to do which is to insert a new line (0x0a) in the text so that the cell shows multiline text. For some reason I'm unable to make that work as they seem to be removed when the xls file is actually written (I'm guessing).
Try updating the value in the CellExported event. This event is fired after the exporter has written the data to the cell, so any changes you make shouldn't be overwritten again.
