420
Using TemplateBlueOrange as an .isl file
hi how can i use this "TemplateBlueOrange" , it is in XML , tell me how can i use this as an  .isl file ,Sorry i am new to using the appStylelist, do i need to save and change the extension or something like that
  • 469350
    Templates are not meant to be used directly. A Template can be used within the AppStylist application to generate a style library. Basically, the template is sort've like a style library with no color information and you pick the colors.
    There are a whole bunch of style libraries included with NetAdvantage and they have a ".isl" extension. If you want to create your own style library from a template, then open up the AppStylist application and select Create New Style Library and the wizard will give you the option to create one from a template and walk you through the process step-by-step.
