I am using the UltraCalendarInfo control, version: 8.1.20081.1000
Its tied to a UltraMonthViewSingle component.
It appears that the code in the designer.vb file for the UltraCalendarInfo is loading before the data source is available, causing a Inner Exception. If i manually edit the designer.vb file and move it to the bottom of the Initialize Component sub, it runs great. If i make any changes in the design mode to the component and save, it gets repositioned above the data source once again and causes the inner exception.
I know i can bypass the designer and create the component in code, but if i can avoid this i would like to.
Any ideas?
Jennifer
I had a similar problem with the UltraWinGrid. To get around the problem, I extended the grid class with a boolean that gets set when the InitializeLayout event is fired. This happens when the datasource is changed. I put a check in the InitializeRow event that skips out if my boolean is false. I'm sure you can do somthing similar with the calendar control.
Thank you for that suggestion : )
I will implement that check and work around this, not sure what to call it.. Bug, undocumented feature.. lots of choices there!
To get by yesterday i used to code option to get some more progress on this app.
Thanks again,
