460
Copy and Paste Functions
I have this written this code
 if (tvMenu.SelectedNodes.Count > 0)
          tvMenu.CopySelectedNodes();
tvMenu.PasteNodes(tvMenu.SelectedNodes[0].Parent);
it works fine except for the fact that the Copy dose not seem to be copying the tag of all the tree nodes.  I store an object in there that when a user clicks on it, it needs that object to do several other things.  Is there a way to tell the copy command to copy the tag info as well.
  • 69832
    Suggested Answer
    I just checked the code, and we are indeed copying the Tag over when the pasted node is created. The likeliest explanation is that the object that you are assigning to the Tag explanation is not marked with the [Serializable()] attribute and/or does not handle serialization/deserialization of itself.
