750
using series?
Hello all,
I’ve been tasked with moving some Excel code and charts into a real program and while I’ve got the raw data and calculations moved, it’s now time to show the graph.
The excel chart is based on a pivot table so what I think I need to do is:
1.       Figure out all the distinct values of the ‘pivot column’ from the data set
2.       Then do a filtered query on each distinct value to generate a ‘series’
3.       Then add each of these series to the chart.
Right?
I’ve attached a picture of the chart I’m supposed to duplicate.  The pivot column is the ‘1000’, ‘2000’, ‘3000’, etc… and each series from my query looks like this:
The ‘1000’ series:
Date                Position
7-01-2009           -232000
9-01-2009            560000
10-01-2009           -50000
12-01-2009           -70000
The ‘2000’ series:
Date                Position
7-01-2009            355000
9-01-2009            -21000
10-01-2009           217000
12-01-2009            90000
etc..
Am I even approaching this correctly or is there an easier way?
Any advice would be great!
Gene
