280
Sort on a hidden column
I have a Time column that is string formatted in "HH:mm:ss" format.The sort on this is set to descening , some times the sort is not correct as it is a string.
I already have a hidden column that has values in ticks.So when ever the user tries to sort on time column, i thought i would apply the sort order on this
hidden column. How do i acheive this??
I dont want to use the sort comparer as it is taking some cpu.
While going through some other posts i saw that setting the headerclickaction to external will help , but i only want to perform my sorting on
the hidden column only when the user clicks on the Time Column.
Thanks in advance,
Vj
