I am creating a new band and using Grid.DisplayLayout.BandsSerializer.Add(band) to add the band to the grid. When I try to access Bands[0].Columns[0], the columns are not yet created. When do the columns get created? Is there any method I can call to create them?
The BandSerializer is intended for internal use by the grid as part of it's Serialization/Deserialization. You should never use this class.
You cannot add bands to the grid. The grid's bands are determined by the data source of the grid.
The grid must have a data source in order to function. So if you want to use the grid and just set up your data structure at run-time without any database, I recommend using the UltraDataSource as your grid's DataSource. You can add the bands and columns you want to the UltraDataSource and bind it to the grid.
