750
SaveLayout and Dynamic panels/controls
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
I’m having trouble saving my UltraDockManager layout.  I believe it’s because I’m dynamically creating my panes and controls, but I’m not sure.
Here is where I’m creating the basic 4 panes.  (I’m doing this in the Form_load)
      // create a dock area on the right to contain the rich text
      DockAreaPane dockAreaFloat = new DockAreaPane(DockedLocation.DockedRight);
      // initialize the size of the dock area
      dockAreaFloat.Size = new Size(120, 200);
      // contain the rich text pane in the dock area
      for (int i = 1; i < 5; i++)
        DockableControlPane paneUC = new DockableControlPane();
        paneUC.Key = "paneUC" + i.ToString();
        paneUC.Text = "UC " + i.ToString();
        DashboardComponentUC UC = new DashboardComponentUC(m_store);
        UC.Title = "New " + i.ToString();
        UC.RaiseControlSettingsChanged += HandleSettingsChange;
        paneUC.Control = UC;
        dockAreaFloat.Panes.Add(paneUC);
      udmDashboard.DockAreas.Add(dockAreaFloat);
      // if there is a layout file, load it up.
      if (File.Exists("C:\\a.xml"))
        udmDashboard.LoadFromXML("C:\\a.xml");
When I close the form, all I do is:
      udmDashboard.SaveAsXML("C:\\a.xml");
When I run the program and there is a saved layout file, I seem to end up with a couple of extra ‘DashboardComponentUC’ in the controls list, which makes things ugly.  if there isn't a saved layout file, everything is fine but obviously the saved layout wasn't loaded.
What am I doing wrong?  My goal is to build a ‘Dashboard’ with a variable number of panels, so I need to able to dynamically add them.
Any advice would be very helpful!
Gene
