AFAIK when providing a DataTable to a chart, each row is a serie, with each column corresponding to a column of chart. The value of the "cell" is the value drawn.
Swapping columns and rows lets me draw *one* serie where the DataTable is given as a collection of rows of label/value pairs.
Is it possible to draw a chart with *multiple* series as collections of label/value pairs? I tried to set the data source with a DataSet that contains several DataTable's each one representing a serie. It didn't work, it only draws one serie.
BTW, the chart is a 2D LineChart.
-Hernán.
this is possible if you use the Series collection as a datasource. just add several NumericSeries, and bind each one to a different DataTable in the DataSet.
if you are using the DataSource property of the chart, you must bind to a single table, although that could be used to generate several series if SwapRowsAndColumns = true and you have several numeric columns in your table.
