40
Recieving an Error after Dynamically changing the style of a cell
I have a WinGrid that has two columns.  The first column contains a ValueList.  On selecting an item from the value list I would like to change that rows second column to a new style (example, DropDownCalendar).
I am able to accomplish this, and correctly select a date from the DropDownCalendar afterwards, with the following code:
Private Sub ugMyUltragrid_CellListSelect(ByVal sender As System.Object, ByVal e As    Infragistics.Win.UltraWinGrid.CellEventArgs) Handles ugCustomFilters.CellListSelect
  Me.ugMyUltragrid.ActiveRow.Cells(1).Style = ColumnStyle.DropDownCalendar
End Sub
 With the following code I am able to display the DropDownCalendar, however, I get a "The given key was not present in the dictionary" if I select a date:
 Dim cs As ColumnStyle = ColumnStyle.DropDownCalendar
 Me.ugCustomFilters.ActiveRow.Cells(1).Style = cs
End Sub
Any reason why this is occuring?
Note:  We are currently using v6.1 of the UltraWinGrid.
Thank you,
Mark
  • 469350
    Suggested Answer
    Hi Mark.,
    I'm not sure I am following you. You say that this works fine if you set the style to an anum value directly, but it does not work if you first store the enum in a variable? I can't see how that can possibly make any difference.
    Can you post the call stack of the exception?
