I have a ScatterLine chart with multiple data series. I want to be able to control the appearance of the lines in the chart based on the data. The data provides a series of points (which I plot successfully) and also attributes for each point which I want reflected in the color of the point and the thickness of the line segement.
I have tried using the ChartDrawItem event to modify the PE properties but cannot seem to get this to work. I used the following code (largely cut and paste from an earlier post)
This method is triggered by the charts ChartDrawItem event.
Any suggestions on what I am missing?
thx
l.
private void ultraChart1_ChartDrawItem(object sender, Infragistics.UltraChart.Shared.Events.ChartDrawItemEventArgs e)
if (e.Primitive is Polyline)
Polyline pl = (Polyline)e.Primitive;
for (int x = 0; x < pl.points.Length; x++)
try
if (Convert.ToDouble(pl.points[x].Value) < 0)
e.Primitive.PE.Fill = Color.Red;
e.Primitive.PE.Stroke = Color.Red;
e.Primitive.PE.StrokeWidth = e.Primitive.PE.StrokeWidth * 20;
catch { }
finally { }
Ahh. The real world values in are an array in Polyline.points.value.
just discovered that the coordinates in the PE.points collection must be screen coords. - So, how do you convert to 'graph' coordinates?
