I have an issue in LabelTool. I have added a LabelTool in a ribbon group for occuping some space and allignment of other controls, this works and gives the appearence which I need in maximised state(Form) . But when the Form is restored one cross mark is seen in the place of LabelTool.
Ceaser
Ceaser,
The build of 8.1 you are using is the release build; try upgrading to the latest service release and see if that helps.
~Kim~
The version i am using is 8.1.20081.1000.
This is the main form not the MDI child form, is there any relevance With this issue?
Can you give me the build number of the NetAdvantage for Windows Forms volume you are using? Also, I'm not entirely sure from the screenshot but it looks like this is occurring in a MDI child form, is that correct?
I am attaching with the image. Also let me correct you, this is seen when the form is restored and in maximised state it is displayed correctly.
Please check this link then you will get an idea why I have inserted LabelTool.
http://community.infragistics.com/forums/p/25285/92707.aspx#92707
Ceasar,
What version of NetAdvantage for Windows Forms are you using? Can you post a screenshot of what you are seeing when the form is not maximized?
