215
DateTime format problem
I think i found a problem with DateTime Cells and Excel2007 workbook format. This problem occur only if you reWrite data on an existing worksheet. In this case the date format is lost and you have to select all datetime cells on Excel to set their format to Date and get the right date format.
Writing same data in a new worksheet doesn't lost the date format.
if the worsheet exist :
workBook.Worksheets.Remove(workBook.Worksheets[worksheetName]);
worksheet = workBook.Worksheets.Add(worksheetName);
Initialize all cells from a database, the datetime format is lost
If the worksheet doesn't exist
The datetime format is ok
This problem doesn't occur for Excel2003 format.
Best regards
Florent, French
