The ValueChanged event appears to fire if the user clicks the down arrow and then scrolls down the list. Is there a way to get the ValueChanged to fire once the list goes away? I do not want the ValueChanged firing over and over again as the user scrolls through the list.
Thanks for the response Mike. I toyed with the AfterCloseUp last night and I think it will do what I need.
No, there's no way to do that. Once you arrow to a new item, the Value of the control changes and thus the event has to fire.
Perhaps what you could do is put a check for IsDroppDownDown inside the ValueChanged event and just bail out when it's true. Then you could trap the AfterCloseUp event and do whatever processing you want.
