2387
Advanced DataBinding w/ columns
I have a WinTree which I want to totally populate via DataBinding.  The root nodes are of one type and children nodes are of a totally different type.  On the root node, the code calls:
treeNode.Nodes.SetDataBinding(childDataSource, string.empty);
And the children are displayed showing the first property of the object in which the given node is bound.
There should be two columns from the childDataSource displayed.  How does one go about setting up a column set for the children such that dataBinding knows which columns in the dataset to bind to?
When I try putting in a property name, which happens to be a property of a derived class, there are no children:
class base { public string name { get; set; } }
class derived : base { string details { get; set; } }
class CustomDataSet : BindingList<derived> {}
I want to show both the name and details under the root.  The root is of a different type not shows in this code
Sam
Parents Reply Children
No Data
