140
How do I tell which button in ChartDataClicked ?
Hi.
How can I tell which button was clicked in the ChartDataClicked event handler?
I get a ChartDataEventArgs object but this doesnt seem to tell me which button was used. Is there any way to tell this?
I am using NetAdvantage 8.1
Tks
Dan
  • 7305
    Verified Answer
    If you deffinitely need to handle ChartDataClick event, then what you can do is create a global variable, set it the the value that you obtained from ChartDataClicked event, and then use MouseDawn event to obtain button (left/right) such as:
           ultraChart1.ChartDataClicked += new ChartDataClickedEventHandler(ultraChart1_ChartDataClicked);
           ultraChart1.MouseDown += new MouseEventHandler(ultraChart1_MouseDown);
           private double dVal;
           private bool sw = false;
           void ultraChart1_ChartDataClicked(object sender, ChartDataEventArgs e)
                dVal = e.DataValue;
                sw = true;
           void ultraChart1_MouseDown(object sender, MouseEventArgs e)
                if (sw)
                    MessageBox.Show(e.Button.ToString() + ", " + dVal.ToString());
                sw = false;
