Hai To All,
I m using Infragisctics 2008 volume 3. I want to create a grid (cross tab grid). How to create it. Is there any sample code to create it? Is it possible to generate it in run time? Thanks in advance.
You should post your question in the WebGrid forum.
Hi Vince McDonald,
i am in need of creating a Cross Tab Grid in Web, can i follow the same instruction as for wingrid.
I need instructions for doing the web based cross tab grid using infrajustics webcontrols 2009 vol 2
With Regards
V.G.Selvakumar
Senior Software Programmer
mukeshwa,
You would typically be better off posting this in our WebGrid forum. I'm leaving your posts connected to this thread, rather than splitting them off, since it's easier to keep enough context to understand your posts by leaving the thread intact.
WebGrid does not have the row layouts functionality that WinGrid possesses. This type of UI with WebGrid would be difficult to implement, if it's even possible.
If you'd like to discuss this further with relation to WebGrid, please post to our WebGrid forum.
I read your reply regarding corss tab query asked by suresh. it is created in Wingrid. Is it possible in Ultrawebgrid? I am unable to find RowLayoutStyle.GroupLayout in ultrawebgrid. Can you please help me to implement such type of grouping in Ultrawebgrid. I found the article for wingrid like
Grouping Columns in Row Layout using code
but I am unable to find the same stuff for web.
Please reply
Thanks & Regards
While I am looking for cross tab report/grid, I found that you have sucessfully created the report/grid..
I need your help to create the grid(see pic). Can you send me the code how to create the cross tab grid. I have a table having the following Columns
State,City,PROD_TYPE,VALIDATION_TYPE,PRIORITY,CALC1,CALC2
I apreciate and very thankful for your kind help.
Thanks & Regards,
Tanish
