1401
Maximum size of the label on any AxisItem of a composite chart
I want to get the maximum size of the label on any AxisItem of a composite chart.
Any idea how I can get this maximumsize occupied as a size object?
Also please throw some light on how the AxisLabelInfoCollection is being used
internally.
Parents
No Data
Reply
  • 28496
    Suggested Answer
    i think this code will help:
            private void ultraChart1_FillSceneGraph(object sender, FillSceneGraphEventArgs e)
                Axis layerXAxis = this.ultraChart1.CompositeChart.ChartLayers[0].ChartLayer.Grid["X"] as Axis;
                float maxLabelWidth = float.MinValue;
                float maxLabelHeight = float.MinValue;
                foreach (Primitive p in e.SceneGraph)
                    Text t = p as Text;
                    if (t != null && t.bounds.Top > layerXAxis.startPoint.Y)
                        // assume this is an x-axis label since it's below the x axis
                        SizeF labelSize = Platform.GetLabelSizePixels(t.GetTextString(), t.labelStyle);
                        maxLabelWidth = Math.Max(maxLabelWidth, labelSize.Width);
                        maxLabelHeight = Math.Max(maxLabelHeight, labelSize.Height);
    internally.
    it's used for processing the labels through anti-collision algorithms when Axis.N.Labels.Layout.Behavior is set to Auto or UseCollection.  i don't there is any use for this class in an application.
Children
No Data
