I am creating a search box, which dynamically displays the search results as you type.For these purposes I am using an UltraTextEditor control with an UltraGrid as the drop-down control (DropDownEditorButton).Because there are different number of results on each keystroke, I would like to resize the UltraGrid to the proper size.Unfortunatelly the UltraTextEditor/DropDownEditorButton seems only to refresh the size on dropdown event.Which only happens for the first time, because I keep the results visible...How can I dynamically resize the UltraTextEditor/DropDownEditorButton's control to refresh, on each TextChange event?Regards,Mike
Thanks, Mike.
I will try this out.
I just tested this out and it worked fine for me:
DropDownEditorButton button = this.ultraTextEditor1.ButtonsRight[0] as DropDownEditorButton; button.CloseUp(); button.DropDown();
What event isyour code in? This will only work if the editor is in edit mode, which means the control has to have focus.
My code is DropDownEditorButton.CloseUp(); DropDownEditorButton.DropDown();
I get this error when running.
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text **************System.InvalidOperationException: The associated editor must be in edit mode to be dropped down. at Infragistics.Win.UltraWinEditors.DropDownEditorButton.DropDown() at ESPN.DMS.TC.UI.Controls.ResourceSelectorControl.ultraButtonFind_Click(Object sender, EventArgs e) in c:\temp\Phoenix\FormsAndProviderServices\Source\Clients\CMMN\Utility\ResourceSelectorControl.cs:line 436 at System.Windows.Forms.Control.OnClick(EventArgs e) at Infragistics.Win.UltraControlBase.OnClick(EventArgs e) at Infragistics.Win.Misc.UltraButtonBase.OnClick(EventArgs e) at Infragistics.Win.Misc.UltraButton.OnMouseUp(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------TestHarness Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/temp/Phoenix/FormsAndProviderServices/Build/Bin/Debug/Client/TestHarness.exe----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------DMS.Proxy.Entity.Common Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DMS.Proxy.Entity.Common/1.0.0.0__bdbb3667a266745c/DMS.Proxy.Entity.Common.dll----------------------------------------System.Runtime.Serialization Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.648 (Winfxred.004506-0648) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll----------------------------------------AuthComponent2 Assembly Version: 3.0.0.0 Win32 Version: 3.0.0.0 CodeBase: file:///C:/temp/Phoenix/FormsAndProviderServices/Build/Bin/Debug/Client/AuthComponent2.DLL----------------------------------------System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Microsoft.Web.Services3 Assembly Version: 3.0.0.0 Win32 Version: 3.0.5305.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.Web.Services3/3.0.0.0__31bf3856ad364e35/Microsoft.Web.Services3.dll----------------------------------------System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll----------------------------------------DMS.Client.Framework.ApplicationFramework Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DMS.Client.Framework.ApplicationFramework/1.0.0.0__bdbb3667a266745c/DMS.Client.Framework.ApplicationFramework.dll----------------------------------------ESPN.DMS.TC.UI.FindResources Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/temp/Phoenix/FormsAndProviderServices/Build/Bin/Debug/Client/ESPN.DMS.TC.UI.FindResources.DLL----------------------------------------ESPN.DMS.TC.UI.BaseForms Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/temp/Phoenix/FormsAndProviderServices/Build/Bin/Debug/Client/ESPN.DMS.TC.UI.BaseForms.DLL----------------------------------------ESPN.DMS.TC.UI.Base Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/temp/Phoenix/FormsAndProviderServices/Build/Bin/Debug/Client/ESPN.DMS.TC.UI.Base.DLL----------------------------------------System.ServiceModel Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.648 (Winfxred.004506-0648) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll----------------------------------------TopCoder.Util.ExceptionManager.SDE Assembly Version: 1.0.1.0 Win32 Version: 1.0.1.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/TopCoder.Util.ExceptionManager.SDE/1.0.1.0__b7567367622062c6/TopCoder.Util.ExceptionManager.SDE.dll----------------------------------------TopCoder.Util.ExceptionManager Assembly Version: 1.0.1.0 Win32 Version: 1.0.1.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/TopCoder.Util.ExceptionManager/1.0.1.0__b7567367622062c6/TopCoder.Util.ExceptionManager.dll----------------------------------------Infragistics2.Win.UltraWinStatusBar.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinStatusBar.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinStatusBar.v7.1.dll----------------------------------------Infragistics2.Win.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.v7.1.dll----------------------------------------Infragistics2.Shared.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Shared.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Shared.v7.1.dll----------------------------------------ESPN.DMS.TC.UI.Utility Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/temp/Phoenix/FormsAndProviderServices/Build/Bin/Debug/Client/ESPN.DMS.TC.UI.Utility.DLL----------------------------------------Infragistics2.Win.UltraWinToolbars.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinToolbars.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinToolbars.v7.1.dll----------------------------------------Infragistics2.Win.Misc.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.Misc.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.Misc.v7.1.dll----------------------------------------Infragistics2.Win.UltraWinEditors.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinEditors.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinEditors.v7.1.dll----------------------------------------Infragistics2.Win.UltraWinGrid.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.v7.1.dll----------------------------------------System.Design Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll----------------------------------------Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------TopCoder.WinForms.Validator Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/TopCoder.WinForms.Validator/1.0.0.0__b7567367622062c6/TopCoder.WinForms.Validator.dll----------------------------------------DMS.Proxy.ApplicationHost Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/temp/Phoenix/FormsAndProviderServices/Build/Bin/Debug/Client/DMS.Proxy.ApplicationHost.DLL----------------------------------------SMDiagnostics Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.648 (Winfxred.004506-0648) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/SMDiagnostics/3.0.0.0__b77a5c561934e089/SMDiagnostics.dll----------------------------------------TopCoder.Services.WCF Assembly Version: 1.0.2.0 Win32 Version: 1.0.2.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/TopCoder.Services.WCF/1.0.2.0__b7567367622062c6/TopCoder.Services.WCF.dll----------------------------------------System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll----------------------------------------System.WorkflowServices Assembly Version: 3.5.0.0 Win32 Version: 3.5.0594.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.WorkflowServices/3.5.0.0__31bf3856ad364e35/System.WorkflowServices.dll----------------------------------------System.ServiceModel.Web Assembly Version: 3.5.0.0 Win32 Version: 3.5.0594.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel.Web/3.5.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll----------------------------------------Microsoft.VisualStudio.Diagnostics.ServiceModelSink Assembly Version: 3.0.0.0 Win32 Version: 9.0.21022.8 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.Diagnostics.ServiceModelSink/3.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Diagnostics.ServiceModelSink.dll----------------------------------------System.IdentityModel Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.648 (Winfxred.004506-0648) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.IdentityModel/3.0.0.0__b77a5c561934e089/System.IdentityModel.dll----------------------------------------Microsoft.Transactions.Bridge Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.648 (Winfxred.004506-0648) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.Transactions.Bridge/3.0.0.0__b03f5f7f11d50a3a/Microsoft.Transactions.Bridge.dll----------------------------------------System.Transactions Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll----------------------------------------System.EnterpriseServices Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll----------------------------------------System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------ESPN.DMS.TC.UI.Equipment Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/temp/Phoenix/FormsAndProviderServices/Build/Bin/Debug/Client/ESPN.DMS.TC.UI.Equipment.DLL----------------------------------------Infragistics2.Win.UltraWinTabControl.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabControl.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabControl.v7.1.dll----------------------------------------Infragistics2.Win.UltraWinExplorerBar.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinExplorerBar.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinExplorerBar.v7.1.dll----------------------------------------Infragistics2.Win.UltraWinDock.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinDock.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinDock.v7.1.dll----------------------------------------Infragistics2.Win.UltraWinCalcManager.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinCalcManager.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinCalcManager.v7.1.dll----------------------------------------Infragistics2.Win.UltraWinDataSource.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinDataSource.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinDataSource.v7.1.dll----------------------------------------Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------TopCoder.UI.Navigation Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/TopCoder.UI.Navigation/1.0.0.0__b7567367622062c6/TopCoder.UI.Navigation.dll----------------------------------------ESPN.DMS.TC.UI.People Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/temp/Phoenix/FormsAndProviderServices/Build/Bin/Debug/Client/ESPN.DMS.TC.UI.People.DLL----------------------------------------Infragistics2.Win.UltraWinSchedule.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinSchedule.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinSchedule.v7.1.dll----------------------------------------Infragistics2.Win.UltraWinSpellChecker.v7.1 Assembly Version: 7.1.20071.1055 Win32 Version: 7.1.20071.1055 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinSpellChecker.v7.1/7.1.20071.1055__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinSpellChecker.v7.1.dll---------------------------------------- ************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled. For example: <configuration> <system.windows.forms jitDebugging="true" /></configuration> When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
For example:
Yes, I beleive you can. There are DropDown and CloseUp methods on the DropDownEditorButton. So you can get the button from the ButtonsRight (or ButtonsLeft) collection and then cast it to a DropDownEditorButton and call CloseUp and DropDown.
