Hi, is it possible to separate the value from the text in the ultragrid cells?
I have an ultragrid cell with the value "inner" but I want the text to be able to display a localised version of that term (since my project will be used in many different countries), the logic of the project however requires that the cell value be in English.
I could create a new column for the text and make the english column hidden, but before I make that decision I was wondering if there would be an easier more efficient way to achieve the same result?
Any help would be appreciated!
Adem
That's great, thank you for your quick reply!
In those cases we use a ValueList attached to the column. Using the value as the value and displaytext will be the localized text.
Best regards,
Ingo
