225
SavetoXml/LoadfromXml Upgrade Problem
After upgrading from V8.2 to 9.1 we have some problems, hopefully you can help us:
Our Users can save/load their personell DisplayLayout preferences via SaveToXml/LoadFromXml.
With 8.2 everything is fine but 9.1 is not able to read the "8.2" Xml.
This is what we do:
Dim u32 As System.Text.Encoding = System.Text.Encoding.UTF8
Dim input As Byte() = u32.GetBytes(dr(0)("XML_File"))
Dim ss As Stream = New System.IO.MemoryStream(input)
XX_grd.DisplayLayout.LoadFromXml(ss, PropertyCategories.All) <- Error Object not set to an.......
Any Ideas?
Thank you
Matthias
