2945
ExpandableGroupBox and UltraFlowLayoutManager
I'm trying to use the two controls above, to auto-arrange group boxes nicely.
I have an ordinary UltraGroupBox and an UltraFlowLayoutManager.  I've set the ContainerControl of the UFLM to the groupbox anad set orientation as horizontal.
Within the groupbox, I have added a couple of UltraExpandableGroupBoxes.  I have two issues with this:
1)  The UEGB is created in code, and I have placed controls within it (actually using another UFLM).  When this is initially rendered, the box is a particular size.  If I manually collapse and open the box again, it is a slightly different size.  Why is it not going back to the initial size it was?  And if the UEGB thinks that is a better size for the control, how can I set it to that size initially?
2)  When I collapse the first UEGB, why doesn't the second UEGB move to the left to fill the gap, since there's a FlowLayoutManager on the parent control.  Is there a way I can enforce this?  Otherwise, I'm struggling to see the benefit of the expandable control.
Campbell
