Hi If a user changes a particluar column width, I want to save this new value. How do I find which column the user rezised? Regards JensB
Use the Save and Load methods on the grid's DisplayLayout.
Hi Mike,
I have a similar need. Our users are now requesting that we save any and all their column width changes along with sort orders that may been set by them. What is the best way to accomplish this?
Thanks.
<[Infragistics] Mike Saltzman> wrote in message news:108848@forums.infragistics.com... You might want to consider using the Save and Load methods on the grid's DisplayLayout, rather than saving indivisual column widths yourself. Mike Saltzman R&D Engineer Infragistics, Inc. http://community.infragistics.com/forums/p/28025/108848.aspx#108848
Mike Saltzman
R&D Engineer
Infragistics, Inc.
<[Infragistics] Matt Snyder> wrote in message news:108311@forums.infragistics.com... You can use the AfterColPosChanged event to get the new width of the column: private void ultraGrid1_AfterColPosChanged(object sender, Infragistics.Win.UltraWinGrid.AfterColPosChangedEventArgs e){ if (e.PosChanged == Infragistics.Win.UltraWinGrid.PosChanged.Sized) { UltraGridColumn col = e.ColumnHeaders[0].Column; int newWidth = col.Width; // Do things with the width... }} -Matt http://community.infragistics.com/forums/p/28025/108311.aspx#108311
-Matt
