1180
Perfomance issue with set wingrid.Header.VisiblePosition
I am currently upgrade Infragistic 8.2 to Infragistic hotfix 8.2.0.2. However, I met some performance issue when I am using Header.VisiblePosition function.
When I looked in to Infragistic.Win.UltraWinGrid.ColumnHeader.SetVisiblePosition, I found there is a new method in it called RecalculateMetrics which took a lot of time.
Is there a way that I can not using this method when SetVisiblePosition? I found this method will only be executed when hasSuspendedMetricsCalculation flag is false (This flag can be set in ColumnCollection.SuspendMetricsRecalculation). However, since it is a internal method, I can not access.
Could you advise on this? I found the same performance issue with Infragisitc 9.1 as well when setVisiblePosition.
Xin
