Hi, How can I change the image of the menu button? Please see the attached screenshot. Thank you.
The area you're looking change is called the "Application Menu button". Set the Ribbon.ApplicationMenuButtonImage property of your WinToolbarsManager component to change this image.
This information is taken from the following post:http://forums.infragistics.com/forums/p/15350/56291.aspx#56291
