425
Issue with highlighting a row
Hi i have used outlook express style for the tree and added check boxes to the nodes.  There is some problem when the node is selected for which check box is added.  Total row is not highlighted.  Image is attached herewith.
for other nodes the highlighting the done properly.  Can any one suggest how to solve this problem.  If i remove the m_ultraTreeNode.Override.CellClickAction = CellClickAction.EditCell; it highlights properly but i cannot select/deselect the check box.
Thanks & regards,
Sriram Sarma.
  • 69832
    Suggested Answer
    The behavior is by design; the node is selected, but there is an ActiveCell, so to highlight it visually, it is drawn without the selection colors so as to distiguish it from the other cells.
