690
UltraMonthViewSingle: InitializeWeek events firing too early
We're hooking up events to InitializeWeek.  We're also subclassing UltraMonthViewSingle so that we can assign our default values to properties in the constructor of the derived class.
We've noticed that the three Initialize events (Day, Week, Month) will fire off as soon as we set some of the control's properties.  These are the properties we've identified as causing the immediate firing:
                CalendarInfo.FirstDayOfWeek
                CalendarInfo.MaxSelectedDays
                CalendarInfo.SelectTypeActivity
                WeekHeaderDisplayStyle
Our assumption is that the control shouldn't behave this way as we're not aware of UltraGrid or other controls in the library firing Initialize events this early.
Should we be using the control differently, or is our assumption correct?
