With infragistics ribbon its possible to put an image as a caption. Is it possible to make this image transparent and if yes how?
Thanks in advance
Mike Evans
Hello Mike,
It is possible to put an image as a caption.
What you could do is the following:
//Setting the desired Image ultraToolbarsManager1.Ribbon.CaptionAreaAppearance.ImageBackground = Bitmap.FromFile("YourImageHere.jpg"); //Setting the desired AlphaLevel ultraToolbarsManager1.Ribbon.CaptionAreaAppearance.AlphaLevel = 128; // Use the set alpha level or choose another option from the enumaration ultraToolbarsManager1.Ribbon.CaptionAreaAppearance.ImageBackgroundAlpha = Infragistics.Win.Alpha.UseAlphaLevel; //Set the style of you background image ultraToolbarsManager1.Ribbon.CaptionAreaAppearance.ImageBackgroundStyle = Infragistics.Win.ImageBackgroundStyle.Centered;
Sincerely,
Danko
Developer Support Engineer, MCTS
www.infragistics.com/support
