1140
UltraGrid Designer...
I'm getting VERY annoyed (it seems like I'm annoyed a lot, doesn't it...) with the custom Grid Designer.  I Manually Define my data schema and select the "Will be supplying a datasource at runtime" option.  I know it has a "Note" that informs me it will only save the Keys and Positions of the Columns and Bands, but the question is WHY???
Why can't it save whatever property settings I make (such as Hidden) so that I don't HAVE to set them programmatically?  In fact, I can't even find how to set the Column property "Hidden" programmatically.
Why can't it save my property settings so that the next time I open the UltraGrid Designer to modify one of my grids, I don't have to RESET EVERY SINGLE #@$%^&* PROPERTY that I've changed from the default?
It gets REALLY OLD resetting the same properties over and over and over....
Every time I go
