Does the EditorWithText control support multiline text box?
In my use case, a sub-class of EditorWithText control is embedded into an UltraGrid cell, the Embeded text box keeps getting set as (multline= false) after entering into edit mode..
I got around that by overriding DisplayTextBox and setting the multiline properly myself. But after exiting edit mode, the cell still only display the first line of the text.. Is there anyway to get it to show the entire text? The cell is wider than a single line, so there's plenty of screen real-estate.
This worked as expected. Thank you very much.
The EditorWithText does support multiline text, but the problem here is that the multiline setting is ultimately resolved by the owner, not the editor; in this case the grid determines whether the editor should support multiline (if the editor is intrinsically able). What you need to do is set the CellMultiline property on the column (or the Override object) to DefaultableBoolean.True .
-Matt
