445
Row Edit template not updating the datasource
Using VS2008, Infra Win Form 9.1 with all hotfixes.
Did the rowedit template example in the local documnetation following the directions.
Created the datasource and created the rowedit template per the directions. Used the fefaults given in the local documentation
the template opens up fine, can edit a text box and click the OK button. The grid shows the changes, but when I stop (exit out of)  the app and go back in, the changes are not there. I tried this in VS2005 as well -- same result.
this should work with the grid datasource setup exactly as the local help file for binding to a flat file
Oh, I am running Vista so I suspect something there maybe the real issue
Any ideas?
