380
Copy UltraTree node to Clipboard
If you right-click on an UltraTextEditor, a standard menu appears, allowing Undo, Cut, Copy, Paste, Delete, Select All.
The functionality behind the selection made is automatically provided.
If you right click a node on an UltraTree, the node is highlighted automatically.  Canthe UltraTree then have the same enu and automatic Copy functionality as the UltraTextEditor?
       If so, how do I enable it?
       If not, what is the command to copy the text of a selected tree node to the clipboard?
Many Thanks,
Kate Smile
