We need to implement a design mode where our users should be able to customize the conditional formatting on the columns of the grid.
Infragistics already has a complete conditional formatting dialog which can be used at design time, but is it also possible to popup this dialog at runtime?
I am referring to this document:http://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR2.0/html/Win_Implementing_Conditional_Formatting_at_Design_Time.html
To use that dialog at run-time, you will need to add a reference to the SupportDialogs assembly to your project. Then you could do something like:
private void button1_Click(object sender, EventArgs e){ UltraGridColumn column = this.ultraGrid1.DisplayLayout.Bands[0].Columns[0]; ConditionValueAppearanceForm form = new ConditionValueAppearanceForm(column); if (DialogResult.OK == form.ShowDialog(this)) { column.ValueBasedAppearance = form.ConditionValueAppearance; }}
-Matt
