1360
Adding a texteditor to the header
I am trying to add an editable text editor into the header, so that the user can "set" the caption of the header at runtime. However, I am running into two problems:
1. The initial caption of the header isn't set in the text editor.
2. The text editor doesn't enter in edit mode, so I can't enter text.
We are using v7.3
This is my creation filter:
internal class DesignCreationFilter : IUIElementCreationFilter
        public DesignCreationFilter()
        public bool BeforeCreateChildElements(UIElement parent)
            return false;
        public void AfterCreateChildElements(UIElement parent)
            try
                if (parent is HeaderUIElement)
                    parent.ChildElements.Clear();
                    var column = (UltraGridColumn)parent.GetContext(typeof(UltraGridColumn));
                    var editorText = new EditorWithText();
                    var editorOwner = new DefaultEditorOwner();
                    var editor = new EditorWithTextUIElement(parent, editorOwner, editorText, column.Header, true, true, true, false);
                    Rectangle rect = parent.ClipRect;
                    rect.Inflate(-2, -2);
                    editor.Rect = rect;
                    editorText.TextBox.Text = column.Header.Caption;
                    editorText.TextBox.ForeColor = Color.Black;
                    editorText.TextBox.Enabled = true;
                    editorText.TextBox.ReadOnly = false;
                    parent.ChildElements.Add(editor);
            catch (Exception ex)
Any ideas what could cause this behaviour?
Many thanks!
