Hello
I didn't find a way to format the summaries column
I want the average, and Sum summaries column to be formated the same way the column is
Is that possible ?
Thanks for your replies
Use the DisplayFormat property on the SummarySettings. This is the object that is returned to you from the Summaries.Add method.
