Hi there,
I created a small test where I'm using an UltraTree with cells. I would like to cancel the edit mode if the text is equal to "foo". In this case I set e.Cancel to true but it doesn't seems to work.
Here is my test code:
public partial class Form1 : Form { UltraTreeNodeColumn _colName = null; UltraTreeNodeColumn _colValue = null; UltraTreeNode _node1 = null; public Form1() { InitializeComponent(); InitTree(); InitValues(); } private void InitTree() { UltraTreeColumnSet rootColumnSet = this.ultraTree1.ColumnSettings.RootColumnSet; this.ultraTree1.Override.CellClickAction = CellClickAction.EditCell; // Use the 'OutlookExpress' ViewStyle; reduce indentation a little this.ultraTree1.ViewStyle = ViewStyle.OutlookExpress; this.ultraTree1.Indent = 10; // Only allow one node to be selected at a time this.ultraTree1.Override.SelectionType = SelectType.Single; _colName = rootColumnSet.Columns.Add("Name"); _colName.DataType = typeof(string); _colName.LayoutInfo.PreferredCellSize = new Size(this.ultraTree1.Width / 2, 0); _colValue = rootColumnSet.Columns.Add("Value"); _colValue.DataType = typeof(object); _colValue.LayoutInfo.PreferredCellSize = new Size(this.ultraTree1.Width / 2, 0); _colValue.AllowCellEdit = AllowCellEdit.Full; // Auto-fit columns this.ultraTree1.ColumnSettings.AutoFitColumns = AutoFitColumns.ResizeAllColumns; } private void InitValues() { _node1 = ultraTree1.Nodes.Add("key1"); _node1.SetCellValue(_colName, "Text1"); _node1.SetCellValue(_colValue, "Value1"); UltraTreeNodeCell cell1 = _node1.Cells[_colValue]; cell1.Editor = new EditorWithText(); cell1.Editor.Tag = _node1; cell1.Editor.BeforeExitEditMode += new BeforeExitEditModeEventHandler(Editor_BeforeExitEditMode); } void Editor_BeforeExitEditMode(object sender, BeforeExitEditModeEventArgs e) { EditorWithText editor = sender as EditorWithText; if (editor != null) { if (editor.CurrentEditText.Equals("foo")) { MessageBox.Show("Invalid"); e.Cancel = true; } } } }
Thanks for your help...
It works !
Thank you
Sorry, I should have try this...
Strictly speaking, that is a bug - UltraTree handles the editor's BeforeExitEditMode event as well, and it is not checking the value of e.Cancel in its handler before proceeding. What you should do is handle UltraTree's BeforeCellExitEditMode event instead...you can do the same thing therein, the only difference being that the sender in that case will be the UltraTree. You can get the editor from the e.Cell.EditorResolved property.
Thanks for your answer but this is not the MessageBox. Actually I added a MessageBox just for the example.
I suspect is might be the MessageBox that is causing a problem. If you show a MessageBox, it will take focus. Thus the tree will lose focus and be forced out of edit mode.
